BarCode Reader
BarCode Reader
Our shop is looking for a inventory program that will allow us to scan a barcode, put it in inventory, then take it out and put on customer ticket. What is everyone using?
Re: BarCode Reader
That would be interesting--- We do everything by hand now---
But the thought is a great one...
Re: BarCode Reader
Manager SE supports bar code scanning as it is a different interface method to record user selections. Here is an instructive comment from 2013:
"Welcome to the Forum. I've posted many times on barcode scanners. You can use the Search function in the upper RH corner here and find them all.
What I found is best is what they call a 'plug and play' scanner. These require no software at all. They essential act as a keyboard, so your cursor needs to be where you want it before pulling the trigger.
What I also found is that the barcode on most automotive parts rarely resembles the part number we use. I've been entering the barcode number into the Alt part number area of my inventory records so they 'connect'.
This not an integrated solution by any means. Just a way to quickly transfer information. Frankly I've not found any real daily advantage to it's use at the current level. We really need something designed for Manager specifically."
Re: BarCode Reader
That post sounds familiar, hmmmm........
I am now using a Bluetooth wireless scanner. I can scan vin's into Manager, as well as scan parts into the order. I've been updating my parts labels to include a barcode. It's far from seamless and certainly not an integrated solution, but it works.
I use it now mostly for VIN entry. We get a lot of new vehicles from used car lots and they all need to be entered. None of the have plates for decoding, so VIN is the way to go. Parts entry is clunky enough at this stage that I don't use it much.
Ideally, especially on larger jobs, you'd want some sort of device that can collect multiple parts for input later. They make stylus and fob style scanners for this now. Someone would need to integrate that into Manager. Based on how long we've been talking about this, I'm guessing it's not high on the M1 priority list.
