6.6.12 System Values Changed?
sbcauto
Post by sbcauto »
since my update yesterday, every time I open a estimate, a box opens saying that taxes have been change-update this work order. my tax info has not changed. I can open estimate many times getting the same message. I do check box to update. is there a way to stop this from happening. thanks
Re: 6.6.12 System Values Changed?
This is only the orders on the WIP screen and a one time event. It sees *something* as a change in system values. Say NO then print the estimate or write down the totals. Open it a second time and see if anything changed (doubting it will change) Once you answer YES to acknowledge the dialog, it won't ask again. If it keeps asking *after* you replied yes, contact support.
