Saving Portion Of Estimate?
OK so I make an estimate for a customer. It has diag time on it and the estimate for the job. They decide not to do the job but I still need to bill them the diag time. Is there a way to just bill the diag time from the estimate and leave the rest there in case the decide in two weeks to get the work done?
Re: Saving Portion Of Estimate?
Move the actual work to a Revision/Sub-Estimate tab so you can quickly sell it to a new Order. It's best practice to also make a Recommendation on the it so you can run a report to remind yourself to pursue the work if you want.
In case you're wondering how to move the work, highlight the lines on the order, Ctrl+C, then open a Revision and Ctrl+V. Once you're sure everything looks good, you can delete the lines from the current estimate.
Thanks!!
