history
bill@superior
history
Post by bill@superior »
Is There A Way To Delete Vehicle History As Of a Certain Date. Customer Purchased New Vehicle & used Same Plate. So Not All The History Is Valid To The New Vehicle. I Know Old Vehicle Should Have Been Removed Before Starting New Vehicle But That Did Not Happen Here. Thanks
Re: history
Did you create a new vehicle or did you overwrite the old vehicle data with the new vehicle data?
If you create a new vehicle, the history will stay separate. Don't worry about the plate. You can simply delete the plate on the old vehicle and add it to the new. NEVER overwrite vehicle data with a DIFFERENT vehicle.
If you DID overwrite the data and haven't done any work yet, set it back to the old vehicle and create a NEW one.
If you have service history for both vehicles combined on one AND you have ProPack, there is a 'Move History' function that can be used. Return the vehicle record to the original, create the new vehicle and move the selected history to the new vehicle.
