History record dates
I have noticed lately that when going to F4, then searching by Vehicle, the search date appears to default back only 2 months. Example, I just searched for a vehicle, it shows
Posted From 04/04/2020
To 06/04/2020
The car I was looking for was from last year. I had to back date the "from date".. Then got out of the F4, short time later I went back in and the date is back to 04/04 - 06/04.
Am I missing a setting?
V 8.2.0.141
Re: History record dates
I think it defaults to 60 days. Not a sticky setting?You can save a search on the other F4 tab.
Ugh....If i find a genie I am going to revamp all of the date stuff. :shock:
While this does sound exactly like the sort of defensive measure we'd implement for avoiding search criteria that might time out, it's not the behavior I see using this function.
My F4 > Vehicle search continues to show the last searched term and results until I hit the Clear button. Perhaps you can confirm that's the case, Rich? In which case, if you want to start with a 2 year range by default for example, don't clear your results, just change out the term and search again.
*Update* It appears to reset if I leave Manager for another application, but why would you ever need to do that? :P
