Using ShopKey Away From Shop?
Since the pandemic hit, many sensitive businesses were able to work remotely, has Shopkey enabled remote working.? The manager is getting tired of coming in on the weekends to catch up on paperwork he could do from home. Such as closing invoices and checking PO'S. Most of our customers have charge accounts. Also, does the Quickbooks integration work remotely?
Re: Using ShopKey Away From Shop?
We use a program called splashtop. We can log into the shop computer remotley with it and do any thing we need to do. I do a lot of my paperwork at night after i get home and settled for the evening.
is there an extra cost? That is exactly what manager is trying to do.
ShopKey SE shop management is a desktop program running on a local area network (LAN). Having said that, there's at least a dozen 3rd party solutions that let you access the shop PC from home. LogMeIn, GoToMyPC, TeamViewer and others like Splashtop mentioned here. You're basically driving the PC remotely. This would include whichever QB interface (legacy M1 or AccountingLink) you're using.MURRI513 wrote: ↑Mon Jul 12, 2021 4:21 amSince the pandemic hit, many sensitive businesses were able to work remotely, has Shopkey enabled remote working? The manager is getting tired of coming in on the weekends to catch up on paperwork he could do from home. Such as closing invoices and checking PO'S. Most of our customers have charge accounts.
I use the free version of TeamViewer to control multiple computers; as long as I don't connect to a PC at the corporate office I'm fine. They see that as commercial usage and that's using the business pay version.
Thank you for help, another reason why I love this forum.
Does the host computer have to stay on at all times? Would I have to change the settings so my terminal(host) doesn't go to sleep?
The manager is actually buying the company, so he is now asking all these questions.
You would install a remote client on the workstation PC that you expect to make changes from. Should be able to set the connection to allow for an unattended connection (nobody needs to be there, exchanging passwords, etc.) The workstation PC must be turned on; ShopKey SE running or you start it. (it's just like sitting in front of the PC)
The Host PC needs to remain available to record changes in the database.
My SA got sick during COVID and had to work from home for 2 weeks. We used Teamviewer and I set up an IP phone extension. Worked like a charm except it took up a lot of bandwidth. I upgraded to 100meg fiber and it's a lot better.
