SE Export File Type Preference
liljoe
Post by liljoe »
When doing an export on a report, it would be nice if the file type selection was sticky so it would remember to select the correct file type (.rpt, .pdf, .xls, ect) when exporting a report, I keep forgetting and wind up sending invoices that can not be opened by the customer. Thanks.....
Re: SE Export File Type Preference
If we're talking about current documents (Est / RO / INV / Revision), the only choice is pdf sent as attachment with email client. So you must be referring to a need to send invoice from History screen? I'll submit the Adobe PDF option to be the default there if possible.
liljoe
Post by liljoe »
That is correct, also when the Email button does not want to work ( most of the time it will work on the second try, but not always ) I need to export them to a file and then Email them. Thanks....
Adding the send from History to the change list.
