Print Part Codes?
Print Part Codes?
is there a way to print the part codes ? there is a print button , but does nothing.
Re: Print Part Codes?
Welcome to the forum John and thanks for your question.
Ther Print button you see in Setup is there to print setup information (doesn't matter which tab you're on prints the same stuff).
Under Reports - Inventory tab, there are two print part code list in either Code Order or Description order.
is there a certain screan on need to be in to add a new part code ? it keeps telling me i need a code to save it , any ideas anyone
Yes. Text entries like that are handled in Setup screens. Go to Setup - Standard Descriptions, Part Code tab as shown below:
Manager SE Help screen text instructions: http://managerhelp.buymitchell1.net/Partcodedescpt.htm
- code.png (48.55 KiB) Viewed 4096 times
What if I don't see an inventory tab in the reports window?
Welcome to the forum and thanks for your question.ppark1229 wrote:What if I don't see an inventory tab in the reports window?
If you do not see Inventory tab then you have Manager and not Manager Plus. If you are referring to the Part Codes lists, they can be found under the Management tab in Manager.
