Inventory - Stocked Parts
plaza automotive
Post by plaza automotive »
I know in old 5.9 you used to be able to add a part to inventory and keep a certain number of the part number "on hand" is there a step I am missing in SE that has that functionality?
Re: Inventory - Stocked Parts
Inventory QOH (Quantity On Hand) works the same way on either platform; what are you not able to do?
plaza automotive
I am unable to find the location of the QOH screen.
plaza automotive wrote:I am unable to find the location of the QOH screen.
QOH is visible in the Part Item Entry/Edit window for an inventory item on the Order screen. On Hand is a field on the RH side of an Inventory record; just above On Order and Committed fields.
plaza automotive
It's not on my screen when i do it that way.
Do you have Manager only?
Manager Plus will always display these as follows:
From Order screen, Part Item Entry:
NOTE: QOH dimmed as this is not a stocked part; if a stocked item it would be lit and display actual quantity.
Inventory Part - Part Item EDIT:
plaza automotive
timbre4 wrote:Do you have Manager only?
Manager SU is what it says at the bottom of the screen next to the software version.
That would be Manager SE single user and this is why the inventory aspects do not appear. This can be upgraded.
plaza automotive
timbre4 wrote:That would be Manager SE single user and this is why the inventory aspects do not appear. This can be upgraded.
Thank you. I appreciate your patience with me in this!!
