Oreilly/Auto Value Internet down?
- rhillig
When I try to go into either of those catalogs, I get a message that says internet down. I can get into the Napa cataloging - so I know we can access the internet.
Re: Oreilly/Auto Value Internet down?
Just checked it from here....got in no problem.
- rhillig
Thanks for checking - it appears to be working again here as well.
ours has been slow for a few days.
- rhillig
I spoke too soon. I can get on them on one computer - but the other two - I get this error message:
Error Page Exception
SRVE0260E: The server cannot use the error page specified for your application to handle the Original Exception printed below.
Original Exception:
Error Message: java.lang.VerifyError: JVMVRFY027 receiver is incompatible with declaring class; class=tools/ICIXMLParser, method=parseFromStringAndGetDocument(Ljava/lang/String;)Lorg/w3c/dom/Document;, pc=82
Error Code: 500
Target Servlet:
Error Stack:
at servlets.InternetCatalog.getEncodedECIXML(InternetCatalog.java:746)
at servlets.InternetCatalog.doGet(InternetCatalog.java:278)
at servlets.InternetCatalog.doPost(InternetCatalog.java:158)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:595)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:668)
at com.ibm.ws.webcontainer.servlet.ServletWrapper.service(ServletWrapper.java:1230)
at com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest(ServletWrapper.java:779)
at com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest(ServletWrapper.java:478)
at com.ibm.ws.webcontainer.servlet.ServletWrapperImpl.handleRequest(ServletWrapperImpl.java:178)
at com.ibm.ws.webcontainer.filter.WebAppFilterManager.invokeFilters(WebAppFilterManager.java:1071)
at com.ibm.ws.webcontainer.webapp.WebApp.handleRequest(WebApp.java:3837)
at com.ibm.ws.webcontainer.webapp.WebGroup.handleRequest(WebGroup.java:304)
at com.ibm.ws.webcontainer.WebContainer.handleRequest(WebContainer.java:981)
at com.ibm.ws.webcontainer.WSWebContainer.handleRequest(WSWebContainer.java:1662)
at com.ibm.ws.webcontainer.channel.WCChannelLink.ready(WCChannelLink.java:200)
at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleDiscrimination(HttpInboundLink.java:459)
at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleNewRequest(HttpInboundLink.java:526)
at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.processRequest(HttpInboundLink.java:312)
at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.ready(HttpInboundLink.java:283)
at com.ibm.ws.tcp.channel.impl.NewConnectionInitialReadCallback.sendToDiscriminators(NewConnectionInitialReadCallback.java:214)
at com.ibm.ws.tcp.channel.impl.NewConnectionInitialReadCallback.complete(NewConnectionInitialReadCallback.java:113)
at com.ibm.ws.tcp.channel.impl.AioReadCompletionListener.futureCompleted(AioReadCompletionListener.java:175)
at com.ibm.io.async.AbstractAsyncFuture.invokeCallback(AbstractAsyncFuture.java:217)
at com.ibm.io.async.AsyncChannelFuture.fireCompletionActions(AsyncChannelFuture.java:161)
at com.ibm.io.async.AsyncFuture.completed(AsyncFuture.java:138)
at com.ibm.io.async.ResultHandler.complete(ResultHandler.java:204)
at com.ibm.io.async.ResultHandler.runEventProcessingLoop(ResultHandler.java:775)
at com.ibm.io.async.ResultHandler$2.run(ResultHandler.java:905)
at com.ibm.ws.util.ThreadPool$Worker.run(ThreadPool.java:1864)
Error Page Exception:
Error Message: com.ibm.ws.jsp.webcontainerext.JSPErrorReport: JSPG0036E: Failed to find resource /error.jsp
Error Code: 0
Target Servlet:
Error Stack:
java.io.FileNotFoundException: JSPG0036E: Failed to find resource /error.jsp
at com.ibm.ws.jsp.webcontainerext.AbstractJSPExtensionProcessor.findWrapper(AbstractJSPExtensionProcessor.java:447)
at com.ibm.ws.jsp.webcontainerext.AbstractJSPExtensionProcessor.getServletWrapper(AbstractJSPExtensionProcessor.java:338)
at com.ibm.ws.webcontainer.filter.WebAppFilterManager.invokeFilters(WebAppFilterManager.java:997)
at com.ibm.ws.webcontainer.webapp.WebAppRequestDispatcher.dispatch(WebAppRequestDispatcher.java:1385)
at com.ibm.ws.webcontainer.webapp.WebAppRequestDispatcher.forward(WebAppRequestDispatcher.java:194)
at com.ibm.ws.webcontainer.webapp.WebApp.sendError(WebApp.java:3339)
at com.ibm.ws.webcontainer.filter.WebAppFilterManager.invokeFilters(WebAppFilterManager.java:1095)
Original Exception:
Error Code: 500
Target Servlet:
Error Stack:
Error Code: 0
Target Servlet:
Error Stack:
Just in from support:
"Any parts vendors using the IAP systems that go through Manager may have issue either getting in or asking to re-select YMM. They are currently working on restoring functionality. A release build affected the process and they have since rolled back and still getting everything restored. I will keep you updated once I get more information."
