S&G Imported Parts
S&G Imported Parts
I believe their website to be using webware weblink, can we get it added to SE to be used as a mitchell catalog? Their website is http://www.sgparts.com
- Johnny5
Re: S&G Imported Parts
You can easily load the Webware Weblink catalog to Manager SE - the auto install is located at http://m1faqs.com/fix/SE/catalogs/weblink.exe . Credentials and configuration questions should be directed to websupport@weblinkcorp.com
We get parts from S&G through the Local Auto Value store.
Weblink is installed I guess I need to contact support to configure it in the dropdown selection for this vendor. Thanks
Drewman, Where are you from? I am guessing Michigan but where abouts?
My shop is located in Berkley, Rich.
I contacted web support and S&G needs to be enabled in Mitchell. When I go to setup the link on the vendor screen I select weblink as the catalog. Then I enter my username and password and there is a dropdown below that. S&G is not listed there.
How do I go about getting S&G on that vendor list?
Thanks,
Andrew
Thanks,
Andrew
To be clear, you should have a Manager SE vendor record for S&G. Clicking Setup Link would display a list of links that you would then choose Weblink as the type (associates the S&G vendor record to the parts button), enter your account credentials and click OK.
Now when you click the Weblink button on the Order screen, it is associated to the Manager SE S&G Vendor record.
I have done all the vendor setup, it is the credentials thing that is not right. On Webware setup there is a drop down list of vendors, "APM Limited, Arizona Jobber Supply, B2B Demo, Colonial Auto Parts, etc."
How does one get S&G on that list?
