Inventory - Stocked Parts
I know in old 5.9 you used to be able to add a part to inventory and keep a certain number of the part number "on hand" is there a step I am missing in SE that has that functionality?
Re: Inventory - Stocked Parts
Inventory QOH (Quantity On Hand) works the same way on either platform; what are you not able to do?
I am unable to find the location of the QOH screen.
QOH is visible in the Part Item Entry/Edit window for an inventory item on the Order screen. On Hand is a field on the RH side of an Inventory record; just above On Order and Committed fields.plaza automotive wrote:I am unable to find the location of the QOH screen.
It's not on my screen when i do it that way.timbre4 wrote:QOH is visible in the Part Item Entry/Edit window for an inventory item on the Order screen. On Hand is a field on the RH side of an Inventory record; just above On Order and Committed fields.plaza automotive wrote:I am unable to find the location of the QOH screen.
Do you have Manager only?
Manager Plus will always display these as follows:
From Order screen, Part Item Entry: NOTE: QOH dimmed as this is not a stocked part; if a stocked item it would be lit and display actual quantity.
Inventory Part - Part Item EDIT:
Manager SU is what it says at the bottom of the screen next to the software version.timbre4 wrote:Do you have Manager only?
That would be Manager SE single user and this is why the inventory aspects do not appear. This can be upgraded.
Thank you. I appreciate your patience with me in this!!timbre4 wrote:That would be Manager SE single user and this is why the inventory aspects do not appear. This can be upgraded.
