Differential Labor & Parts
Would it be possible to separate the front and the rear Differential labor and parts. Takes time to look thru many different labor heading looking for some way to see which differential assembly or carrier assembly is the front and which is the rear. Sometimes not even able to with no designations on any of them. On 3/4 tons or 1 tons at least sometimes the full floating will help pin down which labor heading is for the rear. But having it say FRONT or REAR would save opening labor heading after labor heading looking for the right one.
Re: Differential Labor & Parts
Thanks for your suggestion; I have moved this into the ProDemand section and sent a copy to the editorial group on your behalf.
