Water Pumps With Timing Belt Jobs?
It would be very helpful to include water pumps as an add to timing belt jobs since most of the timing belts are now done at 100,000+ mile intervals.
Re: Water Pumps With Timing Belt Jobs?
Usually if we are doing a water pump with a timing belt the water pump labour has the timing belt combination labour underneath it. Not sure if this helps.
This is an editorial question regarding Estimator labor practices so I have moved this to ProDemand.
