2005 Dodge Magnum - ATF Checking Procedure
- wbuxton
- 1000 Club: Interstellar
Where can I find information on how to check ATF level in a Dodge Magnum R/T 2005?
William
Weatherford, TX
817-599-7680
866-744-3887
http://www.phoenixtrans.com
William
Weatherford, TX
817-599-7680
866-744-3887
Re: 2005 Dodge Magnum - ATF Checking Procedure
You need to buy a dipstick. Part number 9336A. I have one. I'd let you borrow it if you were closer.
- wbuxton
I've got one from the dealer but don't know how to use it. It looks like a throtle cable on my lawn mower and it is about 18" longer than the tube. I have heard there is a temperature chart you have to reference but I would like to see it in print.
William
Weatherford, TX
817-599-7680
866-744-3887
William
Weatherford, TX
817-599-7680
866-744-3887
I have that chart...sending over.
- wbuxton
Thank you! Germans keep the best secrets.
William
Weatherford, TX
817-599-7680
866-744-3887
William
Weatherford, TX
817-599-7680
866-744-3887
You're welcome.
This can be found in OD5 here......
Automatic Trans>Service Info>Fluid and Filter>Standard Procedure>Check Oil Level>Figure 163
Wasn't easy to find....
- wbuxton
I can hear my nephew saying right now "well I have a monkey for an uncle". Thanks again, I guess I just got frustrated looking.
William
Weatherford, TX
817-599-7680
866-744-3887
William
Weatherford, TX
817-599-7680
866-744-3887
- liljoe
I just use an old speedo cable that I put marks every 5mm to measure the depth of the fluid in the pan and the scanner to check the fluid temp. Who would of believed a few years ago, you would need a computer just to check fluid level?
ya its really kinda crappy for most ppl and then they also ask why is that trans fluid so exspensive. Well its a nissan cvt transmision so its special and cost $350 to flush it
- wbuxton
Just like printers. Buy them for $50.00 and spend $45.00 on cartridges.
William
Weatherford, TX
817-599-7680
866-744-3887
William
Weatherford, TX
817-599-7680
866-744-3887
i guess i'm just accustomed to it. nothing surprises me anymore.
