2007 Ford F350 - No 6.0L Dsl Option?
Questions about VIN, models, engines covered in the repair products
alaskadetailed
Post by alaskadetailed »
i need to repair an 07 f350 with the 6.0l diesel but it is not in the list. it only shows the 6.8 v-10 and the 5.4. why is this????
Re: vehicle info
Not sure if this applies in your case but with the Fords if diesel is wanted, you have to specify F350 Super Duty. Perhaps you are doing this. I brought it up with my system.
alaskadetailed
Re: vehicle info
yep bringing up an f350 4 door supercab
alaskadetailed
Re: vehicle info
nevermind...had to enter it as a chassis cab
fortknoxx
Re: vehicle info
Post by fortknoxx »
when you are picking the engine. go over to the right. (green arrow) find the lil black arrow scroll thing. then scroll down the menu to the 6.0.
I don't know why there are so many of the same engine listed. there are 5 listed all with the P code? this was very confusing for me too
4x 6.8 (Y) motors
4x5.4 (5) motors
5x 6.0 (P) motors
eng list.jpg (115 KiB) Viewed 17168 times
Ruger77
Re: vehicle info
Post by Ruger77 »
I have wondered the same thing. Why so many duplicates? I just figured I was missing something.
Re: vehicle info
i think that it's a shot gun approach. they use all available to insure it's there. one some applications the litre will be the same but there are significant differences in the block that is only noted by the vin. if within the manufacturer application for that particular year and model there are 10 applications that have the same engine you'll see all 10. many are the same but on some there are differences. i scan all applications because some will have turbo and others not with the same vin. it mat seem tedious but it's only the first time and takes a few extra seconds.
crmeyers
Re: vehicle info
Post by crmeyers »
Mine doesn't pull up all those. Are you running SE 6.4 Tina?
Chris Meyers
Service Center Manager
Ocean Air Auto Repair
www.oceanairauto.com
Re: vehicle info
She's running 5.9 and it is handled differently in 6.4.
This multiplexing effect (trucks & vans mostly) is because the engine appears in numerous sub-models, part of F150, part of F250, part of F350, etc. Another thing to watch for in 5.9 is where a 6 cyl engine is sitting at the bottom of the list below the V8 choices.
It's getting better. :|
fortknoxx
Re: vehicle info
Post by fortknoxx »
dino 5.9er we only have 1 xp machine. all others are 2000. i would love to upgrade.
Return to “Model Coverage”
