2004 Ford Ranger - 4.0L TC Tensioner Time?
How long does it take to replace the right timing chain tensioner on a 04 Ranger with a 4.0L SOHC? My Mitchell1 is not saying. This is the one at the rear of the right cylinder head.
Re: 04 Ranger Timing Chain Tensioner
My source says .5 .
Thats what mine says also
Thanks for checking, men. I appreciate the feedback. My estimator is giving the time for a 2.3L 4 cylinder but not for the 4.0L SOHC engine.
Thanks again.
It does say that if chain needs to be doen engien comes out I think ive done these that way before been to long to remember tho
I'm forwarding this to the product support dept within editorial for correction.
brianp87 wrote:It does say that if chain needs to be doen engien comes out I think ive done these that way before been to long to remember tho
Yea yer right. If the timing chain has an issue then the engine has to come out. But in this case, i got a tensioner that is leaking past the seal and was wondering what the time is on it since this job is done under warranty for another company. Hopefully the chain will not jump when I remove the tensioner.
timbre4 wrote:I'm forwarding this to the product support dept within editorial for correction.
Thanks Tim. Mitchell1 is not perfect but it is tooting good.
Return to “Model Coverage”
