1989 GMC Medium Duty - Wiring Diagrams
Questions about VIN, models, engines covered in the repair products
LB
Post by LB »
1989 GMC medium duty truck (3 ton) in need of wiring diagram for the brake lights. Help would be much appreciated.. Thank you :)
Re: 1989 GMC medium duty / need of wiring diagrams
The Medium Truck Subscription might have it.
LB
Post by LB »
Sadly we do not have it here, this is the first time I have had to look anything up for something this size. Customer pulled in with no brake lights.. trying to help them out. Not the size of vehicle to be on the streets with no brake lights. I was hoping someone here may have access to them.
liljoe
Post by liljoe »
Call product support, they will fax you the info you need. Great people.....
LB
Post by LB »
I have a call into them. thank you for that suggestion, totally forgot about them.
Return to “Model Coverage”
