2001 Freightliner FL60 - ABS Issue
Posted: Fri Dec 02, 2011 5:47 am
Hello all.
We have a 2001 Freightliner FL60 here with an ABS problem. Does anyone know what type of ABS system is in this vehicle and how to obtain codes? This is a bit outside my area of expertise. I did a bit of research at the Freightliner site but nothing found there.
Re: 2001 Freightliner FL60 - ABS Issue
Posted: Fri Dec 02, 2011 8:40 am
by mopwrforme
sorry ric i havent had any at all in the shop. havent got a clue.
Posted: Fri Dec 02, 2011 10:31 am
Truck tech on vacation but if i recall there was a big issue with the toner rings rusting up.
Posted: Fri Dec 02, 2011 12:00 pm
Well, I have a sensor hanging in the rear. Truck needs loads of work for inspection. Customer wants to know if there is anything else wrong other than the obvious hanging sensor. I have no idea on how to pull codes on this to see. May have to try a sensor and see what happens. It's definitely broken, but is there anything else......
Posted: Sat Dec 03, 2011 2:19 am
Is this a regular customer?
Posted: Sat Dec 03, 2011 5:25 am
Not really. been 2.5 years since I've seen this truck.
Posted: Sun Dec 04, 2011 5:14 am
Well he's back for a reason. I'm thinking it's because you're fair and will treat him well and probably he's taken it up the breezeway from other shops. I get the sense that you're a well respected shop and some people come and go because they think the grass is greener elsewhere. I'm sure you have customer leave for other shops with the idea of less expensive repairs with the same quality craftsman ship. They usually return bruised and financially battered.
In situations like this, a returning customer, i find myself trying to really impress them so they will return as a regular. When i do this i am more likely to shoot myself in the foot. There is an obvious failure with the sensor hanging. At least you have something you can sink your teeth into. If it's replaced and everything works great, if not then it's not like you're throwing parts at it hoping.
