Mobile Manager Allows Duplicate VIN
Mobile Manager Pro (tablets)
Decoded a VIN with Mobile Manager today. Decoded fine with no issues or warnings. As I was working on the vehicle, a sense of deja vu came over me. I've worked on this vehicle before. I went into Manager and discovered that there were 2 identical VIN's for this customer, an existing one and the one I just decoded.
VIN's are unique and under no circumstances should a duplicate be allowed. Manager had a similar issue and I had to stop decoding VIN's until fixed.
We get a lot of unregistered vehicles so using plate numbers is not an option.
motley06
Re: Mobile Manager Allows Duplicate VIN
Post by motley06 »
Good catch!!!
Auto Repair Coach
Post by Auto Repair Coach »
Gentlemen.
Looking onto this issue, I did duplicate it by approaching the vehicle as if I was entering a new vehicle. Decoded the VIN and started a new estimate on the tablet.
In manager found the VIN entered twice. as you did.
Are these steps similar to what you did?
John Burkhauser
BOLT ON TECHNOLOGY
That's close. I did not START an Estimate with MM, but there was one ready for me. It was reported as a new vehicle, which I decoded and I was not alerted that the VIN was already in the database.
Auto Repair Coach
Got it. Thanks.
A little more research later showed that a few shops have seen this. It has been put into development for a fix.
A fleet situation also.
John Burkhauser
BOLT ON TECHNOLOGY
Also discovered that if I decode with MM using the plate it will also allow a duplicate VIN. Not good.
Auto Repair Coach
Got it and submitting it.
Thanks
John Burkhauser
BOLT ON TECHNOLOGY
Checking in to see where we stand on this. Any word on a fix? We do a ton of work for other shops and most of these vehicles aren't registered when we first see them.
Auto Repair Coach
I'll check.
John Burkhauser
BOLT ON TECHNOLOGY
tanyah
Post by tanyah »
We are still experiencing this issue with MM allowing duplicate VINS. Creates cluster and time consuming work to correct on Manager side. Obviously still no update from development.
I could've sworn I saw this as a fix on the latest release. I even commented on it to my SA. Now when I look it's not there? What gives Bolt On?
Auto Repair Coach
There was a fix released but did not completely solve the problem.
Looking into it again.
John Burkhauser
BOLT ON TECHNOLOGY
Any updates?
Auto Repair Coach
Not that I am aware. Will check.
John Burkhauser
BOLT ON TECHNOLOGY
Return to “Mobile Manager”
