Enhancement Request - Tread Depth
Mobile Manager Pro (tablets)
Cory
Post by Cory »
It would be cool if there was a dedicate inspection line for tire tread depth.
I'm thinking a popup that would ask depth on lf rf rr lr, then record it properly. I know we could create a separate line for each tire, but something like this would save a lot of time.
Re: Enhancement Request - Tread Depth
Cory wrote:It would be cool if there was a dedicate inspection line for tire tread depth.
We created separate "notes" section for inspections it's part of our State Inspection job (in PA we have to capture the brake specs, tread depths, Inspection sticker # as well as the Emissions sticker #) all manually typed in:
BRAKE SPECS F8/32B R6/32B
TIRES LF 5 RF 5 LR 5 RR 5
STICKER #AI#-######## MM/YY
EMISSION #IM#-####### MM/YY
DynaBMan
Post by DynaBMan »
I created a note like this.
TIRE TREAD DEPTH
LF: /32 RF: /32
LR: /32 RR: /32
Larry Jackson
Greg's Too Car Care
Fort Smith, AR
Auto Repair Coach
Post by Auto Repair Coach »
As suggest by the other folks here. You can basically build any tire inspection you want.
Building in the /32 where you just input the actual measurement works.
One way I handled it is:
Anything above 6/32 is Green
5/32 to 4/32 Yellow
3/32 and down Red
This helps in limiting the suggested responses from the tech. But in State inspection you always want to input the actual readings.
John Burkhauser
BOLT ON TECHNOLOGY
Return to “Mobile Manager”
