Fixed: Require/Add Technician Name to Inspections
Currently, Mobile Manager adds the technician name to a new inspection only when there is a default technician in Mitchell. Otherwise, the technician field for an inspection is blank. We often forget to put our name in there. We'll likely get better as time goes on, but it seems to me that the tablet could help us a bit.
There are two ways I can see this happening. One way is to use the assigned technician to the tablet. If I'm assigned then my name automatically appears when I start a new inspection. Another way is to add a rule that requires a name before an inspection can be completed. Either way would ensure a name gets associated with an inspection. I think that this association is important for future reference.
Thanks for considering this request. Mobile Manager rocks!
- Pauls Automotive
Re: Feature Request: Require/Add Technician Name to Inspecti
Ric, I do agree that would be a nice feature and support it 100%. What we do is to assigned the tech on the WIP screen under the "Labor Tech" column and that way all labor items within the repair order get assign to that tech automatically. That way when they tech does an inspection he doesn't even have to think about it. The only hiccup is if he repairs on a particular order are being done by two different techs. Then the SW has to make sure to go in manually and change whichever labor items the other tech did do. In almost 90% of the time this will work fine.
- Auto Repair Coach
Entered as requested.
John Burkhauser
BOLT ON TECHNOLOGY
BOLT ON TECHNOLOGY
Agreed. We have a higher incidence of multiple techs per RO due our procedures, so it's not a viable option for us.Pauls Automotive wrote:Ric, I do agree that would be a nice feature and support it 100%. What we do is to assigned the tech on the WIP screen under the "Labor Tech" column and that way all labor items within the repair order get assign to that tech automatically. That way when they tech does an inspection he doesn't even have to think about it. The only hiccup is if he repairs on a particular order are being done by two different techs. Then the SW has to make sure to go in manually and change whichever labor items the other tech did do. In almost 90% of the time this will work fine.
- Auto Repair Coach
We can add a toggle to turn the feature on and off as wished by a shop.
John Burkhauser
BOLT ON TECHNOLOGY
BOLT ON TECHNOLOGY
Absolutely. Makes perfect sense.
- Pauls Automotive
+1
- Auto Repair Coach
Noted.
John Burkhauser
BOLT ON TECHNOLOGY
BOLT ON TECHNOLOGY
Re: Fixed: Require/Add Technician Name to Inspections
Release 79 has added a prompt when no name is associated with an inspection. Thank you Bolt-On.
- Auto Repair Coach
Very welcome!!!
Please keep the ideas coming.
We do listen.
We do listen.
John Burkhauser
BOLT ON TECHNOLOGY
BOLT ON TECHNOLOGY
