MM Allows Duplicate Labor Techs
Mobile Manager Pro (tablets)
tanyah
Post by tanyah »
We are experiencing an issue where Mobile Manager is allowing duplicate Labor Techs and we cannot remove in Manager. We are left with deleting entire labor line and recreating because we cannot edit either labor line (original or duplicate). However if 2 different labor techs are added and 1 is not needed (entered by error) we can remove that tech. It does not make sense that we cannot remove the duplicate or original but can remove additional techs.
Auto Repair Coach
Re: MM Allows Duplicate Labor Techs
Post by Auto Repair Coach »
Making sure I understand this.
If Bill is assigned to a job, you cannot remove him.
If Bill is twice assigned to a job, you cannot remove him.
You need to replace the labor operation.
If Bill and Ed are assigned. You can remove Ed with no problem.
Is this accurate?
John Burkhauser
BOLT ON TECHNOLOGY
tanyah
Post by tanyah »
Close:
If Bill is assigned to a job. I can remove him regardless of where it was added (Mobile Mgr or Manager)
If Bill is twice assigned to a job, I cannot remove/edit either one
and Yes if Bill and Ed are assigned I can remove Ed with no probem
Auto Repair Coach
Thank you for the clarification.
I'll pass this along to development.
John Burkhauser
BOLT ON TECHNOLOGY
Auto Repair Coach
Try this and see if it works for you.
On the tablet open the job line. Go to Technicians - Tap and hold the technician until the "Remove Technician" window pops up. Select "Yes" and they are removed.
Did this do what you want?
John Burkhauser
BOLT ON TECHNOLOGY
tanyah
Post by tanyah »
Thank you yes that worked.
Auto Repair Coach
Great Thanks.
John Burkhauser
BOLT ON TECHNOLOGY
Return to “Mobile Manager”
