Populate Performed Inspections?
How do I get the inspection sheets to show inspections performed? Thanks, Jeff.
- MRISICH
Re: Populate Performed Inspections?
Hi Jeff,
If you're referring to performing a multi-point inspection in Report Pro, this software solution does not capture that dynamic. Hope that helps.
Mike, when I print the insp sheets everything stays black (never performed). What is the process to enter info to show done or due?
- MRISICH
Hi Jeff,
Have you checked out the step-by-step guide? That should solve this problem. Here's a direct link: http://boltontechnology.com/howdoi.pdf Please let me know if you still have trouble.
