Is there a way I can get my INV/NoHrs/NoRev to print out parts for a labor item underneath instead of off to the side?
For instance, I'd like to see:
Front Pads/Rotors - Remove & Replace
QX334 Brake Pads
AX3300 Rotors
Air Filter - Remove & Replace
AX16188 Air Filter
Instead of:
QX334 Brake Pads | Front Pads/Rotors - Remove & Replace
AX3300 Rotors
AX16188 Air Filter | Air Filter - Remove & Replace
Labor/Parts By Job, Same Column?
Re: Labor/Parts By Job, Same Column?
The format for Invoices is fixed, but what you want is available from Bolt-On Technologies as part of their Report Pro package. They have a section here on the forum and the website is http://www.boltontechnology.com/products.html.
- MRISICH
Thanks Ric. If you would like to learn more about Report Pro, you can watch and listen to a previously recorded Webinar which offers specifics on Report Pro. You can do that, at your convenience, here: https://www.anymeeting.com/WebConferenc ... 54D8828348
Should you have any other questions, or need any additional support, please give us a call at 610-400-1019.
