Remove inspection
- mopar-mechanic
Remove inspection
Is there a way to remove an inspection after a tech has added a second inspection by mistake?
Garage owner/operator entrepreneur
Shopkey Pro Se with Bolt-on addition
Re: Remove inspection
At the tablet, you can go into Inspections and then click and hold the inspection you want to delete. Then answer yes.
- mopar-mechanic
perfect, I searched through the manager system with no luck, swipe left or right, no luck. Press and hold....of course. Thank you Ric
- Auto Repair Coach
Yes. What Ric said!
Most all Android based tools such as copy, paste and delete work normally in Mobile Manager on the tablets.
John Burkhauser
BOLT ON TECHNOLOGY
BOLT ON TECHNOLOGY
