JTMDF4DV6CD045325 "no matching vehicle could be found for VIN" message.
FREE GOOGLE VIN DECODE:
free vin decode for toyota RAV 4 2013
Description: RAV4 (JPP) - ACA3#,GSA3# (0511- )
Region: USA
Model Number: ASA33L-ANPGKA
Engine1: 2ARFE - 2500CC 16-VALVE DOHC EFI
Transmission: ATM - AUTOMATIC TRANSMISSION
Gear Shift: 4FC - ATM, 4-SPEED FLOOR SHIFT
Grade: LIMD - LIMITED TYPE
Paint Code: 8R3 - PACIFIC BLUE METALLIC
Trim_Code: LA10 - ASH
BuildDate: 201201
2012 Toyota RAV4 - No Decode?
Re: 2012 Rav4 no decode
This decodes in ProDemand. As explained above, you do not need to report this.
From above.......... http://www.managerforum.net/viewtopic.php?f=231&t=11570
If you have a VIN that doesn't decode in Manager, try it in ProDemand. If that works, that means it's in a future update for Manager, and will eventually show up. In that case, there would be no need to notify us.
This vehicle decodes in Manager SE 7.0.2 right now. You must be several releases behind, please contact support so that you can get squared away,
We do not have pro demandricmorin wrote:This decodes in ProDemand. As explained above, you do not need to report this.
We just got 6.6.10, showing no updates available at this time.timbre4 wrote:This vehicle decodes in Manager SE 7.0.2 right now. You must be several releases behind, please contact support so that you can get squared away,
Re: 2012 Toyota RAV4 - No Decode?
That is due to the following reasons:
1. SE 7.x will not install on XP / Vista computers
2. The new Scheduler is vastly different and we declined to force that on any unsuspecting shops
If you would specifically like to receive the SE 7.0.2 update, please contact customer service to be placed in that group by account number.
I am reviewing the 7.0 YouTube videos now. Looks like a nice change. Anxious to try it.timbre4 wrote:That is due to the following reasons:
