Hi,
Is anyone else having issues decoding certain 2016 VINs? I used to see this with newer model vehicles, when working at a shop with an older version of SE that required frequent patch installs by the user, but not since moving to a shop that receives auto updates from Mitchell1.
2016 Honda Odyssey
Thanks in advance for telling me exactly why I'm at fault
Jennie
2016 Honda Odyssey "No matching vehicle for VIN"
Re: "No matching vehicle found for VIN"
Don't think your at fault. 2016 is a pretty new vehicle. Some times it takes a little while for the after market folks to get all that caught up.
Since there is plenty of 2016 Odyssey coverage, it should not be a problem. That specific VIN may be missing from our tables; please post it so that I may share with the appropriate department.
Thank you. The VIN is 5FNRL5H65GB021149.
Jennie
Jennie
I can confirm this VIN is mapped and will decode in the next update of the software.
Thank you all for the assist. So glad I finally created a login for this stuff.
Jennie
Jennie
