2016 Hyundai Tuscon VIN Issue
Re: 2016 Hyundai Tuscon VIN Issue
Inquiry being made.GUTHTIRE wrote:2016 Hyundai Tucson Limited - VIN KM8J3CA45GU053015 not decoding.
Here is how the VIN decodes using our source data:
VIN_SIGNI_PATTRN_MASK MDL_YR MAK_NM MDL_DESC TRIM_DESC OPT1_TRIM_DESC OPT2_TRIM_DESC OPT3_TRIM_DESC OPT4_TRIM_DESC DOOR_CNT BODY_STYLE_DESC TRK_CAB_CNFG_DESC DRV_TYP_DESC ENG_DISPLCMNT_CL ENG_VIN_CD ENG_FUEL_DESC ENG_ASP_TRBL_CHGR_DESC ENG_ASP_SUP_CHGR_DESC ACES_VEHICLE_ID ACES_ENG_VIN_ID
KM8J3CA4*GU****** 2016 HYUNDAI TUCSON LIMITED SPORT AND ECO SE 4 Sport Utility Vehicle Sport Utility All Wheel Drive 2.0 4 Gas No No 229044
Note that the engine liter size (ENG_DISPLCMNT_CL) listed above is 2.0. According to Hyundai (https://www.hyundaiusa.com/tucson/specifications.aspx), our MVCs, Kelley Blue Book and Edmunds, the 2.0L engine is only available for the SE sub model. All other sub models (including the Limited) have a 1.6L turbocharged engine.
Our VIN mapping process has checks in place to validate vehicle-to-engine combinations and so it would only recognize SE + 2.0L engine as a valid combination. That is, in fact, what is in MEPS right now (and should be part of the next ProDemand update):
