I do understand that change is often times difficult and does require an investment of time; time spent by development staff, tech support and all of you, the end users. My primary goal has always been, and will continue to be, to deliver a superior, easy-to-use solution that continues to evolve your needs. My life work is Manager software and I work for you. Below listing details changes included in version 7.0.5.
Kind Regards,
John Dwulet
V 7.0.5
- Scheduler Enhancements:
Window now remembers size/position/maximized state for each user
Sched column in WIP as well as WIP Detail Dialog show correct schedule start date - if order is not yet scheduled, shows as blank
Added ability to right click in Sched column of WIP to either show WIP Detail Dialog, or open Appointment editor to edit schedule times
Added Scheduled Hours to Scheduler Appointment and Shop Event tab
'Sched Hours' uses your configured business hours, as well as holidays, to calculate how many actual shop hours each appointment uses. Matches value as in Appointment Editor.
Scheduling tab includes the total scheduled hours for the view you have selected.
Each Day/Week/Month breaks down the scheduled hours for that range (shows on same line as 'Appt' count).
Multi-day appointments will show hours each day based on start/end time and shop hours.
All day appointments use the full shop hours of each day it spans.
Appointment Count on Scheduling tab now includes appointments that started on previous days, but span across multiple days (Order Hrs only shows up on first day of appointment)
Built-in Appointment States now have preassigned colors
Custom Appointment States can define custom colors
State of appointment color shows up on Scheduling tab of Schedule and Appointment Editor
Improved performance of Schedule when loading/refreshing large appointment lists
Improved detection of Host Databases with incorrect versions when Manager starts - will now attempt to update workstation.
Fixed Invoice Validation of assigned Labor/Parts technician - correctly prompt when setting is turned on, and part/labor item has no assigned technician
- Fixed Employee Editor - Phone Mask was causing error loading technicians
Fixed LOF & Symptoms not correctly selecting items
Fixed issues editing phone number on Customer Tab and Telephone Dialog
Handle purging estimates where there was an appointment for the estimate - appointment remains behind and can be deleted or updated
Improved follow-up appointment prompting when posting orders from the WIP
Changing vehicle ownership now prompts to select new tax settings (use customer's or vehicle's)
XCharge - Added support for configuring user name & password within Manager
Updated Report Invoice Hours
Corrected hazmat showing in totals
Increased font size in part and labor description
Updated Recommendation Dialog to make the Category drop down more apparent
Added Order Hours to Appointment Editor
Added Order Hours totals to Scheduler Views
Added Appointment end time rolling over to the next business day where those hours fit within the amount of Order hours (may span several days/weekends)
Appointment end time updated (incremented or decremented) when RO's Order Hours change
