Scheduler Comments Print as Notes Setting?
acofgb
Post by acofgb »
When making an appointment, I type in the comments section what work needs to be done... LOF, rotate, CEL on, brake noise etc. This is then automatically set by default to print to the repair order as a note. I then have to manually uncheck the box next to the command to 'print on order as note'. Is there a way to change this so the box is unchecked by default?
Re: Scheduler Comments Print as Notes Setting?
I looked at settings and this feature appears to be hard coded in the software. Perhaps it would be advantageous to make this a sticky setting like so many others in the program.
