Appointment Moves Into Tomorrow?
ARS
Post by ARS »
We are working the new scheduler but one issue is that it moves the person from today to tomorrow randomly even if we are completing the work order that day. We start with each customer and mark them as an all day event, but it still moves them forward
Re: Appointment Moves Into Tomorrow?
This is most likely due to adding labor time to a scheduled appointment. The automatic growth of appointments is an option we're looking to implement soon, so the appointment duration you set would not change no matter how many labor hours you actually add to the order.
ARS
Post by ARS »
is this something we can do different to correct or is this a fix with an update?
BERGMANS1
Post by BERGMANS1 »
ARS wrote:is this something we can do different to correct or is this a fix with an update?
After you add work, it may stretch across multiple days depending on how much work you add.
For now, the work around is to open the appointment and change the date/time to make it stay on a single day.
