Scheduler Time Increments
On the scheduler it's defaulted to 1 hr grids. You can change it by right clicking on the side bar and changing it. However, when you close the scheduler it defaults back to the hour increment. Is there any way to make the half hour increment a default?
Re: Scheduler
I personally would like to see it broken into tenths. That would match the hours that come out of Mitchell, ie. 2.3 hours to replace the kanooter valve would reflect that time.
Re: Scheduler
I changed mine and the setting stuck, so it's likely something weird.
Do you have that user running on more than 1 workstation? Do you even have users? Or are you using the default?
Try shutting down all workstations except that one, make the change and shut down Manager, then restart.
Re: Scheduler
I must need glasses...looked this morning and tenths are there
