Date/Time Range Box In Appt. Editor
JDAUTO&TRUCK
Post by JDAUTO&TRUCK »
I absolutely HATE the pop up tip box that tells you "the date/time is out of range" when you are setting up an appointment in the future. You click drop off date/time, then your in date/time. As I'm going down to click the promised or "out" time/day, the popup blocks the "out" or "finished" date calendar, so I have to click another day past the "in" day, then reclick the desired day. Either have an alert come up when you set the in/out days and hit save, or have the tip box come up in a specific spot that WONT block the date you are trying to click on. This is VERY repeatable and makes scheduling a pain in the butt when youre busy and tappin' keys
Re: Date/Time Range Box In Appt. Editor
Agreed. M1 is aware of this nuisance.
BERGMANS1
Post by BERGMANS1 »
It is annoying, but an east fix is to do the end time first, then fix the start time. That way it is never out of range and the box doesn't pop up. The other work around is to just make the future appointment for today and then drag and drop the apt for the actual day you want. It's kind of silly, but it works.
