Scheduler Not Populating?
1000 Club: Interstellar
Post by Pauls Automotive »
All of a sudden my scheduler is not populating with the repair orders I put into Mitchell. It also is not retaining anything I put into it within the scheduler itself. Anyone else having this problem or do you know if they are having an issue?
Re: Scheduler Not Populating?
Paul,
Check your filtered settings in the upper left corner of the calendar view. If nothing is showing up, that's almost always why (someone turned off visibility to certain record types). If the Filtering doesn't appear to be the problem, contact support ASAP to ensure you don't have a database issue.
