How to enter Low/High Order with Buy Factor
Posted: Fri Jun 15, 2018 12:00 pm
I buy my oil in Boxes that have 6 - 1 Gallon Jugs in a Box with 4 qts in a jug, what is my Buy Factor?
Create a Unit Conversion in Setup | Unit Conversions | Click Add on the ribbon | Buy Unit = Box | Sell Unit = Quarts | Add description | Ok
On the Inventory Material Card select Unit Conversion as Box to Quarts
Check the box for Sell Fractional Quantity
Buy Factor is 24 ( * Because you have 24 quarts in a Box and 6 X 4= 24 qts)
If you have your Low Order set to 24 it means that you have 24 Quarts left in inventory and you need to reorder!
* It does not mean that you have 24 boxes left!!
