1) Click on the M1 button top left corner with program open
2) Click Manager Options
3) Highlight Security in left panel
4) Click Security Options
5) Click Users from left panel
6) Double click to open User you want to setup Windows Authentication for.
7) Click Windows tab.
9) Click Find Now and select the Windows User and Okay at all prompts.
10) Next time after User log logs onto Windows OS/PC with their credentials and launch Enterprise Pro, on the login screen the User can simply check the box next to “Use Windows Integrated Authentication” without entering password.
Important Note:
1) Make sure that you ONLY use Windows Integrated Security in a Domain Network Environment.
2) In setting this up and you are on Windows tab, it is recommended that you enter Full Users Name as it appears in Active Directory including Domain and click Verify.
3) If you do not know the users name in Active Directory, use the drop down Search in this location and select your domain | Click Browse | Default location is computer.
Important: It is recommended that you do not use any Local Computer Account.
