How to show sub total only on WO & Invoices
M1EnterpriseTech
Post by M1EnterpriseTech »
Can I set it up so my estimates and/or work orders and/ or invoices show sub totals only?
Yes, you can. Please follows instruction below:
  • Go to Setup from the Home Ribbon
  • Type Print in the search field
  • Select Print Documents
  • Click the drop down arrow under Type to select the type of document you want to show sub totals only when printing
  • Click the drop down arrow under Template to select the template you want to show sub totals only when printing
  • Click Edit on the ribbon
  • Scroll down the left panel to select Advanced Options in the Body section
    Check box next to "Do not show pricing information for line item(s)"
    • Click Ok
    • Click Ok again
You are good to go!
Enterprise Support Specialist
