How can I deploy report to another user?
M1EnterpriseTech
Post by M1EnterpriseTech »
In Enterprise Pro you have the option to deploy a saved report to another user.
  • Double click the report to deploy from "My Reports"
  • Click the drop down arrow on the Layout icon on the ribbon
  • Select the Deploy Layout option
  • Check box(s) of the User(s) you want to have access to the report
  • Click Ok
Note: If the user has an existing report with the same name, it will be overwritten by the one deployed to them.
Important Note: As of current (05/2017) the ONLY way to un-deploy a report to a user is to delete it and re-add.
Please give careful consideration to Security when you deploy a report to a user, as it will often allow them access
to other reports under the same Category in All Reports. If in doubt, please reach out to Enterprise Support for assistance
enterprise@mitchell1.com or 1-888-724-6742 ext 4120
Enterprise Support Specialist
Return to “Enterprise: Reports”
