2) Scroll down to bottom of left panel to select Settings under Workstation Setup
3) Select Payment Processing tab
4) Click the drop down arrow for Vendor field to select "360 Payments - Velox"
5) Click "Pair Terminal" button
6) Complete Location | Contact Name | Email Address | Terminal Serial # fields
7) Click OK
Note: System will run through brief series of tests, once completed the "Enabled" box will be checked.
9) In Signature Capture section click the drop down arrow in Device field to select 360 Payments Payment Device
10) IMPORTANT STEP: Click Save on the ribbon to complete the install
