Can I message people in different departments at my shop?
Discussion of Enterprise settings
Pro User
Post by Pro User »
Can I message people in different departments at my shop using the messaging feature?
M1EnterpriseTech
Re: Can I message people in different departments at my shop
Post by M1EnterpriseTech »
Yes! Messaging isn't just for multi locations with Inventory Transfers module activated.
Single location shops can benefit by using messaging internally.
To setup Messaging: ( Note: Module must be activated by programmer first!)
  • Go to Setup from the Home Ribbon | Type "Network" ( minus quotes) in the search box
  • Select Settings | Click Add from ribbon to create Message Groups or add Individuals. [/b]
To send messages:
  • Click on the Messaging module from the home ribbon | Select "Start a new conversation " ( located top left of messaging window)
  • Select Message Recipient from drop down menu (bottom left corner of messaging window) | Type Message | Click Blue Arrow to Send
Note: You will see a bright visual notification on the Messaging module icon on the home ribbon and the total number of messages in a small window
in the bottom right corner with program open
Enterprise Support Specialist
Return to “Enterprise: Settings”
