Setup Enterprise Supplier providing items for multi shops
Discussion of Enterprise settings
M1EnterpriseTech
Post by M1EnterpriseTech »
In an Enterprise/Head Office environment you may need to setup a Supplier that provides items for multiple locations. Please read below:
The key to setting up a supplier to be used by multiple locations is creating the Payable Account at the Enterprise location so that when entries are made on these accounts at the location-level, they go against the Enterprise General Ledger.
Follow these steps to create a new payable with a contact:
  • Click on the Enterprise Setup button in the Home ribbon.
  • In the left window pane, select Accounting | Accounts Payable
  • Click Add from the ribbon to open the Payable Account popup.
  • To create a payable account with a contact, check the first box " Create a contact for the new payable account" option | Click Next
  • Enter the Contact information, click Next
  • Enter all of the information for the account on the General tab.
Note: The steps below are important if you want to make this "Supplier" Contact available across locations as mentioned above.
  • Click Location tab, click Action drop-down | Click Add.
  • Search for the location, click the location. Click OK
  • Click Save to commit your changes.
Enterprise Support Specialist
Return to “Enterprise: Settings”
