Benefit in checking "Lookup Required' for labor or part line
Posted: Fri Aug 09, 2019 8:14 am
There is a benefit to having "Lookup Required" box checked on a Labor Line or for a Material line item in a work order. When you highlight the first line item entry in the work order and select Catalog Lookup on the ribbon the system will go down the list to lookup up labor and parts automatically saving you time by not having to select each line and then catalog lookup.
