Time Manager - Manager SE 8.4 Release
Discussion area for the new Time Manager including Job Clock and Shift Clock
This will be the area to discuss the NEW Time Manager features.
smittylube
Re: Time Manager - Manager SE 8.4 Release
Post by smittylube »
Good Stuff!
I was able to setup the time card.
Note for others using tablets and MPI's
MPI tablet is already using port 9000, I was unable to see the login/ timecard with my phone, only when I used the same tablet was I able to view the time card.
Is another port usable or any options for the phone separate if the MPI is using 9000?
Any suggestions would be welcomed here.
Logging time for a job, First it needs to be a repair order and not an estimate to show up in the time card ( as well as assigned to the tech). I am able to get the rO and jobs to show up for the time card, log time as shift and or job, but the job actual time doesn't show in the RO. It is available in the time clock setup.
Steve Smith
megoff
Post by megoff »
Hi Smittylube, any device that is connected to the shops network/WiFi should be able to connect to Time Manager and clock jobs. Being connected to the same network/WiFi as your Host machine is crucial for Time Manager to function.
If you're having issues connecting the phone for access to the Time Manager please give us a call in tech support and we can assist with troubleshooting the connection. 888-724-6742
Both Prospect and Time Manager are using the same port, 9000, for communication of these services.
smittylube
Will call to get phone working also.
Another note, there is a check mark to the right of the specific job clock once this gets selected the time transfers to the RO labor item! very nice!
Steve Smith
smittylube
You nailed it. For some reason my phone connected to the printer not the wifi of the program.
Golden now. Thanks
Steve Smith
smittylube wrote:
Fri Dec 17, 2021 2:04 pm
Be aware that once this box is checked, it cannot be undone and no further punches can be added. It is final.
smittylube
Thanks for the heads up
Steve Smith
compasstruck
Post by compasstruck »
Mine worked for the first day - it was great and I was looking forward to using it to the full... now it is not working and says "no valid url found". I did call tech support and didn't get to far, not their fault, I also have an IT guy on our side that I have to work with. I guess before I call them back wanted to see if anyone here had a quick fix. Any clues??? Also confirmed that it has nothing to do with antivirus. Thanks in advance!
megoff
Post by megoff »
compasstruck wrote:
Tue Dec 28, 2021 7:59 am
Mine worked for the first day - it was great and I was looking forward to using it to the full... now it is not working and says "no valid url found". I did call tech support and didn't get to far, not their fault, I also have an IT guy on our side that I have to work with. I guess before I call them back wanted to see if anyone here had a quick fix. Any clues??? Also confirmed that it has nothing to do with antivirus. Thanks in advance!timeclock.jpg
Hello Compasstruck,
This could be a few different things, the first thing to try is to close out of the Time Clock Setup and re-launch the page. If that doesn't work, a reboot of the computer may be needed. If there are continuing issues please give me a PM.
nessauto
Post by nessauto »
It looks like it should work great. The information is currently not correct in it. They have a issue with it and they're currently working on a solution. It duplicates the jobs. So say a tech puts on a set of tires, and the labor line pays him 1 hour and he punches in on the job for 1.5. It duplicates that labor line 2-3 times. There's also a few other what I would call Minor issues. Hopefully they get this correct soon.
megoff
Post by megoff »
nessauto wrote:
Wed Dec 29, 2021 5:35 pm
Hello nessauto,
Yes this is a display issue when you start a job then pause it multiple times prior to posting the order. The good thing about it just being a display issue, all the reports like the Tech Recorded Hours and Tech Productivity reports are still displaying the correct information. This issue has been brought up to our development time and should be corrected in a future update. Thank you.
nessauto
Post by nessauto »
It appears at first anyway you are correct. We wanted to use the clock each day to double check techs punches. So to double check we'll have to export it to a report....then check....if adjustments need to be made close the report and recheck...then do it again.. Seems like alot of work...but we'll have to look at it. After further looking into this...yes you are partially correct. While it doesn't export the second and third labor lines into the sheet....it does take into account their numbers when calculating the technicians efficiancy. So you really can't count on that efficiency number being correct.
nessauto
Post by nessauto »
Does the timeclock portal for the techs not put any information into Mitchel until the technician marks it complete? If a tech forgets to punch out on a labor line how do you go in and correct it without waiting until it's posted?
megoff
Post by megoff »
nessauto wrote:
Mon Jan 03, 2022 6:43 am
The Actual hours will update on labor items when the tech marks the labor item as completed or when the order is posted.
nessauto
Post by nessauto »
So if you have a job on the first day and the tech stays punched in on it they need to make a note and wait till the labor opp is completed....then go back in and edit it days later?
megoff
Post by megoff »
That's correct. If the labor items is not marked as completed prior to the order being posted out it may require adjustment days later.
For the Job clock to be accurate it does require your techs to mark the labor items complete at the time of completion.
smittylube
Excellent update guys - Thanks.
I would like to suggest or get suggestions on a scenario please.
Say one RO has 3 jobs - tire rotation .25, oil change .5, brake fluid flush 1.0
Tech works on all 3 at the same time say 1 hr total. if he is clocked in the job clock for all 3 at the same time, he currently logs 3 hrs.
I suggest one option being all jobs for said RO (as the individual job option maybe?). Or did I miss that option somewhere?
Many jobs are multiple jobs at once, taking time to clock in and out on each separate job may not be practical in many instances.
I believe we need this to be easy for the techs to implement to get good results.
Thanks everyone.
Steve Smith
megoff
Post by megoff »
Hello Smittylube, thank you for the feedback on the new Time Manager feature. I will definitely take this back to the team.
With the current version of Time Manger it does combine the jobs in the way you've described below, our current release is a clock in and out of each labor item as they are completed.
nessauto
Post by nessauto »
We downloaded 8.4 and realized all the issues with the timeclock. Any idea when the update with all the fixes is due to be released?
We are working on the issues noted right now; the anticipated Followup release is a few weeks away.
Return to “Time Manager”
