2001 Chev Malibu - Junction Block Conn View?
i need the left junction block connector view. my problem is i have no radio or instrument cluster. i have isolated the switched power wire(purple) has no power on the cluster. but i don't know which purple wire is which, there's a few that split out of the connector. 1 wire goes to the cluster, the other goes to the bcm. please help if you can.
Re: 2001 Chev Malibu - Junction Block Conn View?
Welcome to the forum and thanks for your post. I have moved it to WRENCH: GM Cars for proper visibility.
Forum regulars may chime in with some help, this forum is NOT monitored by product support. They can be reached @ 888-724-6742 or email here: http://www.buymitchell1.com/form/productsupport.htm
I am just a dumb service writer .....but I will try to help. Is this "junction block" one of the fuse blocks? Sorry for dumb question. I will dig into if i can.
yes it is. not a dumb question at all. its the driver's side fuse/junction block
is this a 68 hole or 30 hole connection?
And when you can tell me how many give me your fax number please.
Just throwing it out here, it sounds like an issue with the pcm. The delay timer is im=n it and I've found them failed a bit. Usually if a person jumps the car when the battery is down to nothing and doesn't wait for it to build up. Connect the cables and immediately try to crank over.
