2001 Chev Malibu - Junction Block Conn View?
Posted: Fri Oct 31, 2014 9:33 am
by betts auto repair
i need the left junction block connector view. my problem is i have no radio or instrument cluster. i have isolated the switched power wire(purple) has no power on the cluster. but i don't know which purple wire is which, there's a few that split out of the connector. 1 wire goes to the cluster, the other goes to the bcm. please help if you can.
Re: 2001 Chev Malibu - Junction Block Conn View?
Posted: Fri Oct 31, 2014 9:56 am
by timbre4
Welcome to the forum and thanks for your post. I have moved it to WRENCH: GM Cars for proper visibility.
Forum regulars may chime in with some help, this forum is NOT monitored by product support. They can be reached @ 888-724-6742 or email here: http://www.buymitchell1.com/form/productsupport.htm
Posted: Fri Oct 31, 2014 10:46 am
by Rich
I am just a dumb service writer .....but I will try to help. Is this "junction block" one of the fuse blocks? Sorry for dumb question. I will dig into if i can.
Posted: Fri Oct 31, 2014 10:48 am
yes it is. not a dumb question at all. its the driver's side fuse/junction block
Posted: Fri Oct 31, 2014 11:48 am
by Rich
is this a 68 hole or 30 hole connection?
And when you can tell me how many give me your fax number please.
Posted: Sat Nov 01, 2014 2:49 am
Just throwing it out here, it sounds like an issue with the pcm. The delay timer is im=n it and I've found them failed a bit. Usually if a person jumps the car when the battery is down to nothing and doesn't wait for it to build up. Connect the cables and immediately try to crank over.
