Grandpa gave car to niece, 88k only, clean car. Had towed in, because he tried putting spark plugs in it; couldn't reach under a/c compressor. Ok we finished tune up. Cap, rotor, wires, plugs & replaced corroded module. Car started & ran, but when got warmed up shutoff at idle.Would restart no problem. Asked customer if this was the issue for his reasoning for tune up. He states yes.
Seems to me it was a fuel starve issue, at idle spray with carb cleaner a tad & will run. Figure bad fuel filter. Pulled filter & couldn't even blow through it. Changed filter, car won't even stay running have to drive with two feet to keep idle up. Replaced fuel pump figure weak. Car starts & runs at high idle fine, nice throttle snap, keeps up. Even idles better. Cool, done? Nope!!! Let warm up died out. Pulled back in garage for night. Same thing all over, starts, runs, tries to idle, dies out. Starts right back up???????
Comments,suggestions??????/
