2008 Chrysler T&C - Code P0507
mikemiles
Post by mikemiles »
2008 Chrysler T & C LE with an intermitent code of p0507. We have not found any vacuum leaks and I'm reluctant to replace the throttle body or p.c.m. on such a new vehicle. Any one run into this problem?
Mike Miles
Re: P0507
how many miles on the clock
Re: P0507
I've heard of PCV valves causing this. I think there is an updated number.
Is the idle high?
mikemiles
Re: P0507
Post by mikemiles »
39,000 miles on this critter. I'll check on the p.c.v.
Thanks
Re: 2008 Chrysler T&C - Code P0507
What is warranty? isnt it 100k on newer chryslers?
mikemiles
Post by mikemiles »
I just received the updated PCV, after installation, we will perform the drive cycle for the state inspection. The customer says the dealer warranty is only 34k, but she has an aftermarket warranty also, but I don't think this repair will exceed her deductible. This problem is intermittent, so I'll have to see what happens.
I want to thank everyone for such quick responses. This is the first time to use the forum and I'm impressed.
Thanks,
Mike Miles
It may have been covered, but if she's anything like my customers, they don't want to be bothered by little things. If it got expensive, then I start pointing towards the warranty door. :wink:
mikemiles
Post by mikemiles »
Thanks everyone for your help. The State Inspection is complete and a hundred plus miles and a happy customer.
Thanks again,
Mike Miles
JBUTITTA
Post by JBUTITTA »
Is this the same Mike Miles from Loves Parkansas Il ? jerry
fortknoxx
Post by fortknoxx »
JBUTITTA wrote:Is this the same Mike Miles from Loves Parkansas Il ? jerry
family reunion?
Return to “Dodge Cars”
