1968 Dodge Dart Disc Brake Conversion
midgetbigfoot
Post by midgetbigfoot »
68 Dodge dart 383
Customer installed front disk brakes off a 72 Duster. Said it has new master cylinder but it won't bleed out. I adjusted the rear drums and bleed system. It won't hold pressure. Can I use an O.E. master cylinder or not and what about the proportioning valve? We have done retrofits before. but of course just used a kit.
Any thoughts would be Great. Thanks
Re: 1968 Dodge Dart Disc Brake Conversion
Obviously the calipers take more to work than the wheel cylinders did. he install a master off of a Duster or a Dart. I know if you change over using salvage yard parts the master needs to be updated and in fact the line attachment on the master may need to be reversed to match chamber feeds.
Return to “Dodge Cars”
