2008 Chrysler T & C LE with an intermitent code of p0507. We have not found any vacuum leaks and I'm reluctant to replace the throttle body or p.c.m. on such a new vehicle. Any one run into this problem?
Mike Miles
2008 Chrysler T&C - Code P0507
Re: P0507
I've heard of PCV valves causing this. I think there is an updated number.
Is the idle high?
Is the idle high?
Re: P0507
39,000 miles on this critter. I'll check on the p.c.v.
Thanks
Thanks
Re: 2008 Chrysler T&C - Code P0507
What is warranty? isnt it 100k on newer chryslers?
I just received the updated PCV, after installation, we will perform the drive cycle for the state inspection. The customer says the dealer warranty is only 34k, but she has an aftermarket warranty also, but I don't think this repair will exceed her deductible. This problem is intermittent, so I'll have to see what happens.
I want to thank everyone for such quick responses. This is the first time to use the forum and I'm impressed.
Thanks,
Mike Miles
Thanks,
Mike Miles
It may have been covered, but if she's anything like my customers, they don't want to be bothered by little things. If it got expensive, then I start pointing towards the warranty door.
Thanks everyone for your help. The State Inspection is complete and a hundred plus miles and a happy customer.
Thanks again,
Mike Miles
Thanks again,
Mike Miles
Is this the same Mike Miles from Loves Parkansas Il ? jerry
- fortknoxx
family reunion?JBUTITTA wrote:Is this the same Mike Miles from Loves Parkansas Il ? jerry
